1968 Seats rebuilt, now I sit too high. ?
2 reading
5.4K views 18 replies 15 participants last post by  Woodchuck
I recently took delivery of a 68 car. The front (original low back) seats had been restored with new foam and covers. I literally have to bend my neck forward to sit in the car, my head is jamed into the headliner if I even come close to sitting up straight. I'm 6' and have owned a number of original Shelbys, BOSS cars and other vintage mustangs over the 38 years and have never had this problem, not even close. Last 68 I owned was a GT500 and had zero issues.
Is it just the new foam? I've never had a car with new seat foam. If not, what could it be? If a foam issue, perhaps a 150 lbs of sand bags in the seat for a week will cure the problem.
Thanks!
Thanks for the offer Nick, how does the headroom in your 67 and 68 cars compare to your '65? I have a ton of headroom in my 66, but the seats are all original.. I think there is something going on with the seats in this car, but perhaps it's just fresh foam..
It is hard for me to answer that question because I have 2001 bullet seats in my 65 and 2004 mach 1 seats in my 67. However...I feel like I sit a little higher in the 68 than I did with the 67 old stock seats.
Also....the 68 seats are by far the most comfy classic mustang seats I have ever sat in. I bought another set of 2001 bullet seats to put in the car 7 months ago and haven't put them in because I've been happy how I feel after doing 60 miles in the 68 seats
6'2" and redid my '68 convertible a while back, it was noticably taller than the worn out decades old ones that got replaced, but something sounds off if your head is in the headliner (unless you wear a 24" inseam!)
They will settle a bit, mine dropped about 1" over time, when first done real tight seat-to-steering wheel, now not huge room, but noticeably more.
I bought a 68 GT/CS a year ago, daily driver in "ok" shape, first thing I noticed was I could not see the in-hood indicators, I sit about 1" higher in the convertible and can see them in that car. So as both are OEM frames its the foam/spring settle making the difference.
One thing you can do is put a towel down, then a bit of board that fits the seat insert and drop a cinder block or 3, or something else heavy, on it to help it compress when your not driving...
I'm 6'5" and an old fart. I was 6'7 when I bought my 68 back in 1977. Did the trick to add 2" to leg room as I did with my 64 1/2. Headroom is not a problem. Sounds like you have had your own past experience...you don't need mine!!
I would quit discussing it, take the unholstery off and see what's up (pun intended) with the seat foam.
Slim
Hmm.. interesting subject, I have a 66 with a rebuilt interior.. new seats..I'm 6'1", and my knees hit the door handles when shifting and my head hits the headliner.. i tried to add to the recline of the seat and that helped a bit.. is there anything else to do... mentioning the seat adjustments.. i might try and tinker with that... is there an adjustment possible?
I have '93's in my 65 FB, I'm just shy of 6'1" and have no problem with headroom. Stock old tracks on the seats.
Stan
If it really bugs you, I think that a lot of people here have modified the seat risers by chopping an inch off of the height - some have also built modified seat tracks too IIRC. Don't ask me where those threads are though, you'd have to do a search :)
I'm 6' and I have no problem with my car. BUT, my headliner is higher because I didn't use the old fiberglass insulation pads, I put dynomat in, and the original seat foam is probably close to dying.
Vanscooter yes you could. The seat tracks are the same bolt pattern, they didn't change until 1971.
It takes a lot of sitting and moving around on the seats to get the foam to break down enough to settle. The only reason I have enough head room is that my foam is just about 1/2" thick and the seat frame is broken. Needless to say, Fiero seats are in my future.
Sounds like the best thing to do would be to take a couple inches out of the sides of the seat riser pan.
