Well, I got the official total in on my engine rebuild... It looks icky..
about 800 in labor.. another 700 etc in parts... but that does include the cam, timing set, new pistons and rods, oil pump, etc.. Turns out if you break it down, the heads parts and labor will be around 400-500. (screw in studs, valve seats, rockers, pushrods, springs, valve job, surfacing etc)...
That leaves about $1000-1100 for the engine including cam. I figure that a crate engine will run me $1300 at least, without cam. Engine is only going .030 over, and .010 under on the deck and .010 under on the crank. Make sure everything is straight and ok. I was thinkin' crate engine last night, but after seeing the numbers, it looks less likely. It'll be expensive anyway I do it.
The one good thing out of this whole adventure in spending... 9.0 - 9.5:1 compression and possibily 325-350 HP. My jaw dropped on that one. I was going to ask him what I could do to go from the 250-275 I thought to 300.
So for the question. Does this sound reasonable? Moly rings...flat top pistons, screw in studs, double roller timing (steel, not nylon).. all the labor, etc?
Rich
'66, 302-4bbl, Granada disk brakes, etc, etc...
Rich
