I have a long list of ford part #'s that are supposedly 428 Cobrajet parts. I would appreciate some help identifying the following:
Crankshaft: 1U with a "A" under the 1U, has a 11 on one end of the front counterbalance and a 12 on the other end of the same balance.
Heads: C4AE one has 8090G, the other 6090G next to the C4AE.
Two sets of rods: one set is C7AE-B
the others are C6AE-E
C6AE-E rods have C8AX-6110C pistons attached.
Intake: C7AE9425F (aluminum)
Flywheel: C80E-A
The Block: 9B26. "C" in rear of casting, 352 on back & front. "E" on casting also.
Exhaust manifolds: C80E8431B & C80E8430D
Another block has 66-427 and the "C" in the rear casting with a 9D10.
Also, a "whats it worth" for a set of 428 Cast Aluminum cobrajet valve covers, and a set of original Shelby valve covers with the Shelby American stamping on the inside.
Thanks in advance!!
Anthony
Flywheel: C80E-A
Thanks in advance!!
Anthony
