Bad hips; that sounds like a legitimate reason to go with power brakes.
Yeah, we see many similar debates here and it appears some people misunderstand our advice. We're not saying installing expensive and modern "upgrade" kits are bad or stupid. We're saying they are typically unnecessary. For example, I often see and hear the following:
Myth: Based on what I see on car TV shows, I need a rack and pinion and coilovers to make my classic car drive and steer well
Reality: Your classic car will drive and steer quite nicely with a properly restored and adjusted factory steering and suspension system. If you will be racing the car on curvy tracks, sure, go with coilovers and a rack and pinion. But you don't really need all that on most street cars. The car TV shows install all that stuff because it's donated as a promotion and not because it's the best option.
Myth: I need four wheel discs to make my classic car stop well.
Reality: Rear brakes are mostly along for the ride. The front brakes do most of work. Your classic car will stop quite well with only front discs, or even front drums, as long as everything is properly restored and adjusted. If you want to race on curvy tracks, sure, throw on some rear discs, but you won't need them on most street cars. The car TV shows install rear discs because they are donated as a promotion and not because they are necessary.
Myth: Based on what I see on car TV shows, I need a Coyote swap to make my classic Mustang fast.
Reality: You can get more than enough power from a 1960s Ford V8. Options are infinite and range from mild to completely wild. I've never heard of anyone who installed a 408 stroker and said, "This sucks, I should have done a Coyote swap". The 408 will almost always have more power than the car can put down to the pavement. And, if it doesn't, stroke a big block! The car TV shows do Coyote swaps because the conversion kits are donated as a promotion and not because it's the best option.
Of course, if someone really wants to install coilovers, a rack and pinion, rear disks and a Coyote into their classic Mustang, cool. More power to them. My points here are that all too often people believe without those mods the car will be a floaty, boaty dog that doesn't turn which is simply not the case.
