Spark plug just keeps spinning in aluminum head, now what
18K views 9 replies 9 participants last post by  okcmustangresto
Lets say, hypathetically of course :eek: )that when I went to install my spark plug tonight on my aluminum head that the plug just kept spinning. Yes it is the correct plug, I'm not sure if it was my fault or if the plug or a previous plugs threads were jacked or what. Either way, I am where I am. Now what? :wall: :wall: :wall:
Pull the heads and have steel inserts installed in all the plug holes by a machine shop with experience doing so. They need to be GLUED in with the proper type of compound to ensure they do not come out on you.
BTW...this is a good example why you always use anti-sieze on all spark plugs going into aluminum heads...ALWAYS.
Heli-Coil it! Some aftermarket heads are Heli-Coiled from the factory to prevent just this. Me being cheap, and quick, I'd Heli-Coil it, put the plugs in it and drive it! ::
HTH
--Kyle
PS: I agree. Anti-seize, always! I cracked the ceramic on 4 of the 6 sparkplugs I took out of my Nissan because the last genius didn't use anti-sieze 75k ago.
It gets snug but it isn't right. Did edelbrock honestly make these without the heli coils? Pure aluminum threads? Should I try it while the plug is snug or not chance it and just pull the head. Can't really hurt anything if it doesn't work right? Plug might just tick if it comes loose.
I've used a helicoil on some other parts, the final step in the process is to BREAK OFF the tab that is used to screw the helicoil in. So, if you don't remove the head from the block, you will wind up with a small but destructive piece of metal in the cylinder.
That could really ruin your day! :horror:
